Airbox/BHAF?'s
Airbox/BHAF?'s
Postby 93 W350 LE » Sun May 26, 2013 2:11 pm
Was thinking. Couldn't a guy just cut a big hole in the factory airbox and then cover the hole with metal screen to achieve more airflow? Or does it just look cooler to do the fab work for a BHAF? Is there any real flow or air temperature advantage one way or the other?
Thanks,
Eric
93 W350 LE
Re: Airbox/BHAF?'s
Postby Tacoclaw » Sun May 26, 2013 2:33 pm
There's more surface area to a BHAF than there is with the stock filter, actual filtering area not just how much of the media has access to air. If your truck actually requires the extra air the BHAF provides them yes you will see a benefit. There's nothing bad about getting your engine more air than it needs though, same with getting it out.
You could stick your BHAF in the stock box, if it would fit, and achieve roughly the same thing.
There's really no fabrication needed for a BHAF, it's 2 45* couplers, 2 pieces of straight pipe, and 4-5 clamps. If you want to fab up a fender mount you can but I never did.
Re: Airbox/BHAF?'s
Postby 93 W350 LE » Mon May 27, 2013 6:09 am
Where do you find these big filters? Most of the aftermarket filters I have seen are no bigger than the stock filter. Maybe big truck shop/part store?
93 W350 LE
Re: Airbox/BHAF?'s
Postby Tacoclaw » Mon May 27, 2013 6:55 am
I got mine at Carquest since we have an account there at work, part #87790. They can usually have stuff there next day.
Back when I put the twins on I heard rumblings of BHAFs not being able to support the airflow the bigger turbos were capable of pulling, so I started looking at the dry AFE filters. They are rated for higher flow, and they definitely made more noise than the BHAF, but I think I'd still get a paper filter if I was using a turbo smaller than a 62mm.
Here's their whole universal page, any one with a 4" flange would work, and here's the one I have now.
I think the AFE is about $10-$20 more expensive than the BHAF if you get it off Ebay or something.
Re: Airbox/BHAF?'s
Postby PToombs » Mon May 27, 2013 5:39 pm
I had a BHAF. My 1st one was a Fleetguard, the 2nd is a CARQUEST. I took out my Old Smokey mount and the BHAF because I was drawing more air than it could supply. I think it was the tube from the filter to the turbo though. I removed the filter and with the tube only I could bottom the filter minder. :mrgreen: I paid less for my new AFE 5" flange than I did for my CARQUEST filter.
If anybody is interested the mount and filter are going up for sale. I could be persuaded to get rid of the tubing also. ;)
Re: Airbox/BHAF?'s
Postby 93 W350 LE » Mon May 27, 2013 7:20 pm
I have noticed my stock tube accordions a bit as is. I guess its trying to pull more than the current set up will allow.
Eric
93 W350 LE
Re: Airbox/BHAF?'s
Postby Arnold Layne » Tue May 28, 2013 10:08 am
Hey Pete, I'd like to get into a BHAF setup, if you're going to get rid of yours. :wrench:
Arnold Layne
Re: Airbox/BHAF?'s
Postby PToombs » Tue May 28, 2013 4:40 pm
You're 3rd on the list Arnie! :lol:
Re: Airbox/BHAF?'s
Postby Arnold Layne » Thu May 30, 2013 8:11 am
Sweet! :shock:
Arnold Layne
Re: Airbox/BHAF?'s
Postby RCCUMMINS89 » Thu May 30, 2013 11:12 am
Re: Airbox/BHAF?'s
Postby rockbuggy4x4 » Thu May 30, 2013 1:49 pm
Would you happen to know the filter surface area or the overall size of it?
Jimmy
--> '95 jimmy not so stock
rockbuggy4x4
Re: Airbox/BHAF?'s
Postby RCCUMMINS89 » Thu May 30, 2013 3:53 pm
Hold on, I'll go measure one.
10" diameter x 10.5" tall............. or 329.7 square inches...... remember you don't count the ends, as they are blocked off.
Re: Airbox/BHAF?'s
Postby rockbuggy4x4 » Fri May 31, 2013 7:46 am
Right. So it'd be the height times circumference correct? Either way that's a big filter. lol
Jimmy
rockbuggy4x4
Re: Airbox/BHAF?'s
Postby 93 W350 LE » Fri May 31, 2013 7:50 am
And not much more expensive than the last relpacement filter I bought at Advance Auto parts.
Eric
93 W350 LE Club cab dually automatic, Banks Power Pack w/ exhaust, Banks tach and pyrometer, Isspro boost gauge, GearVendors O.D., BD exhaust brake, Kelderman Compuride and front bags. My Dad was the 2nd owner.
So far; rotated fuel pin, bottomed star,1/2 turn on smoke screw.
Daily driver and occasional 14k lb 5th wheel hauler.
Thank a veteran for your freedoms!
93 W350 LE
Re: Airbox/BHAF?'s
Postby RCCUMMINS89 » Fri May 31, 2013 8:03 am
Unless you go to Napa.........they'll charge you $85
