Puff?
Puff?
Postby Deathrod » Sun May 26, 2013 4:32 pm
I have always wondered what causes the 1stgen start up puff....I have a few guesses but I've never really heard why. Anyone have a technical answer?
Deathrod
Re: Puff?
Postby Tacoclaw » Sun May 26, 2013 4:36 pm
Well, since I'm the only one wiewing this and it could be whole minutes before someone else shows up, I'll throw mu semi-educated guess in here.
The VE pump starts at full fuel, then the governor dethrottles it when the idle speed comes up enough to affect the weights.
Re: Puff?
Postby dazedandconfused » Sun May 26, 2013 4:49 pm
Taco is correct.
Re: Puff?
Postby PToombs » Sun May 26, 2013 6:05 pm
For once. :mrgreen:
Re: Puff?
Postby Tacoclaw » Sun May 26, 2013 6:16 pm
PToombs wrote:As usual
Re: Puff?
Postby turboram » Mon May 27, 2013 8:20 am
Thats why the ve starts better than p pump starts at full rack and has a quicker injection rate
turboram
Re: Puff?
Postby Deathrod » Tue May 28, 2013 1:56 pm
You know what, I did know that......must already be having senior moments over here!!!
Deathrod
