How much additional hp?
Postby 93 W350 LE » Mon May 27, 2013 7:47 pm
Approximately how much power increase is there after turning fuel pin, and bottoming the star?
Thanks,
Eric
93 W350 LE
Re: How much additional hp?
Postby RCCUMMINS89 » Mon May 27, 2013 9:11 pm
Anywhere from 0 to about 25hp
Postby Tacoclaw » Tue May 28, 2013 5:56 am
There's also a little, plastic spacer on your fuel pin that you can remove to get more travel. I pulled mine then just use the coil bind to limit pin travel. That's worked for me so far.
Postby 93 W350 LE » Wed May 29, 2013 6:50 pm
How much more is to be had with the fuel screw?
Thanks.
Eric
93 W350 LE Club cab dually automatic, Banks Power Pack w/ exhaust, Banks tach and pyrometer, Isspro boost gauge, GearVendors O.D., BD exhaust brake, Kelderman Compuride and front bags. My Dad was the 2nd owner.
So far; rotated fuel pin, bottomed star,1/2 turn on smoke screw.
Daily driver and occasional 14k lb 5th wheel hauler.
Thank a veteran for your freedoms!
93 W350 LE
Postby Tacoclaw » Wed May 29, 2013 6:52 pm
With all the free mods, minus drilling the banjos, and a LPLP, my truck put down 268 horse through a Getrag. I'd bet you'll pull ~75 extra horse with a LP upgrade through an auto.
