by Philip » Fri May 31, 2013 6:33 am
CoolTubz's also can supply the pipe to go from the IC to a 24 valve air horn.
Do not use a intake horn off of a common rail engine. It is not the same as a 2nd gen intake horn.
Here is a pic of your intake horn beside a 2nd gen intake horn. Want to guess which one is the 1st gen.
This is a pic of his IC pipe for the 24 valve air horn.
Here is a pic with the inside view of a 24 valve air horn.
This is a pic of a common rail intake horn. Look at the restriction just inside of the air horn where it changes direction. The common rail horn isn't much better than the 1st gen air horn.
