Is this the metal end throttle linkage kit?
Postby Diesel » Fri Jun 14, 2013 7:06 pm
Just making sure before I order - this is the metal ended throttle linkage set right? $36.97 sound right?
http://www.factorymoparparts.com/5011956ab.html
1991.5 D250 Intercooled A518
Diesel
Re: Is this the metal end throttle linkage kit?
Postby Remps » Sun Jun 16, 2013 6:49 am
I got mine from dodge for 25 a couple years ago, they came with a 2nd gen throttle cable.
Postby cougar » Sun Jun 16, 2013 9:06 am
:yuck: :yuck: :yuck: :yuck:
01 2500 "the work truck".
cougar
Postby BILTIT » Sun Jun 16, 2013 10:42 am
Mopar 05011955AB
Cummins 4089076
Derek B.
BILTIT
Postby Diesel » Wed Jun 19, 2013 11:17 am
Bilit,
Thanks man. I bought the part number you posted at my Dodge dealer. For anyone looking I bought MOPAR 05011955AB for $40.20 and there are plenty of them out there I believe.
Diesel
Postby cougar » Fri Jun 21, 2013 8:33 am
cougar
Postby Diesel » Sat Jun 22, 2013 8:20 pm
You sir paid too much I believe? Online seems to be $36 plus ship?
Diesel
Postby cougar » Sun Jun 23, 2013 8:19 am
:twisted: :twisted: :twisted: :twisted:
cougar
Postby Diesel » Sun Jun 23, 2013 5:38 pm
Ah yes Alaska
Diesel
Postby monoblock » Sat Jun 29, 2013 1:00 pm
Diesel wrote:Just making sure before I order - this is the metal ended throttle linkage set right? $36.97 sound right?
Why not use generic parts from McMaster Carr? They have metric+Imperial,even stainless steel & no-lube parts for linkages:
http://www.mcmaster.com/#ball-joint-linkages/=neo04k
http://www.mcmaster.com/#ball-joint-linkages/=neo1u5
This seems so obvious ,ther must be a good reason not to do it? What am I missing?
I was looking at these parts because the ball socket jumped off the ball stud on the Freeway.................Is this a common fault with this linkage?
monoblock
Postby Diesel » Sat Jun 29, 2013 8:13 pm
Yes there is a reason. Because I am lazy, showed up to the parts counter, and got everything in one box. I am willing to spend more to get the job done in one fell swoop.
Diesel
Postby BILTIT » Tue Jul 02, 2013 7:49 am
I second that!
I spend so much time as it is running around getting parts, returning parts that crappy parts people give me and such that knowing i get it all in one and only have to spend time installing it. Well worth the extra $20.
Derek B.
BILTIT
Postby monoblock » Tue Jul 02, 2013 8:03 am
You both make a good case for McMaster Carr
-order on the Internet and top quality items -and cheaper than the dealer.What's not to love?
monoblock
Postby BILTIT » Tue Jul 02, 2013 1:02 pm
Still have to do all the work of figuring out what parts will work.
Its easier to just call the dealer and its there, at least for the first time. Once a person has seen one then its a lot easier to make your own.
Derek B.
BILTIT
Postby PToombs » Tue Jul 02, 2013 5:31 pm
I used 2 ends of p-pump shut off solenoids. Weld 2 bolts back to back, thread on the heim joints, and put them on. I did grind off the ball that was riveted on the 1 end.
