91.5 Not starting
91.5 Not starting
Postby GoonSquad » Wed Oct 02, 2013 2:35 pm
Sold my bmw and picked this truck up for a steal. 91 12v 4x4 reg cab long bed has had turbo work and trans work.So i had it towed to the house. Battery was low so had it charging to start it. For some reason it's not cranking up. i pumped the fuel pump had fuel squirting out the lines i also got a new pump to install. Truck was sitting while the seller was deployed.Any ideas on Geting this baby to purr?
GoonSquad
Re: 91.5 Not starting
Postby dazedandconfused » Wed Oct 02, 2013 5:35 pm
If its getting fuel and turning over check the fuel shutoff solenoid.
Postby GoonSquad » Wed Oct 02, 2013 5:46 pm
i forgot i took apart the fss and it had acorn piece in it. the two wires going to it also werent connect very well i put it back together without the plunger in and still nothing.
GoonSquad
Postby JimmieD » Thu Oct 03, 2013 10:27 pm
Sometimes it helps to crack 3 injectors loose [1-3-5], leave 3 tight [2-4-6], crank engine till it acts like it wants to start. Then tighten the loose injector lines, loosen the others and crank again, till it acts like it wants to start. Then tighten all, crank and let her run.
1967 Dodge D-100 Town Wagon - CPL 858 4BT, HTT Stage II/H1C 16cm/56cm turbo, '93 CTD I/C, 32K spring, minor fuel tweaks, milled head, NV4500, 1 ton springs, '72 D-200 Frt. axle w/ Air Lift bags, 4.10 Dana 60HD, F/R swaybars, Tom Woods shaft.
'90 W-350 gasser...
JimmieD
Postby GoonSquad » Mon Oct 07, 2013 4:41 pm
Roger that! I'll give that a try tonight going to install new lift pump
GoonSquad
