HX 35 swap
HX 35 swap
Postby 91cumminsd250 » Thu Oct 24, 2013 9:18 pm
Hey guys, I've got a 91.5 (intercooled) with the stock turbo, only things I've done really is 4 inch exhaust and a Denny T stage 2 fuel pin. Looking to get a better turbo, just wondering if its worth trying the hx 35 or doesn't it really do much? I've heard it lags with the auto trans. Hopefully it'll whistle a little bit too mine sounds like a tractor still! And anyone have a decent one for sale in northern IN? Thanks
D250, Diamond Eye 4" exhaust, Denny T Stage 2 pin, Homemade intake, Boost/Egt gauges, too many window stickers
91cumminsd250
Re: HX 35 swap
Postby simplysmn » Thu Oct 24, 2013 10:05 pm
Well if you have the fuel pin already I would also add a 366 spring and then toss a hx35 on it yes it will do what you want as for Lag I haven't seen that with mine but I have 410's
simplysmn
Re: HX 35 swap
Postby Hansen01 » Thu Oct 24, 2013 10:06 pm
The hx-35 should come with a 12cm exhaust housing. It was not laggy compared to the stock one when i had one installed
Under construction...
Hansen01
Re: HX 35 swap
Postby 91cumminsd250 » Fri Oct 25, 2013 10:57 am
Thanks, i have 3:54 in the back but looks like i'll give it a try if i can get my hands on one
91cumminsd250
Re: HX 35 swap
Postby cmann250 » Fri Oct 25, 2013 6:51 pm
I see them on CL all the time, but they're overpriced. $200 for a used turbo is crazy in my opinion.
Re: HX 35 swap
Postby coolhand_luke » Wed Oct 30, 2013 10:17 pm
I bought the generic hx35 off ebay and I have been very pleased. Not laggy at all with my auto. You will notice a huge difference when you go from a 21CFM to a 12cfm housing. nite and day. I paid $300 for mine and it was new. People say they break easier than a genuine holset but I haven't had any problems. Easy swap, took about 1/2 hour.
coolhand_luke
Re: HX 35 swap
Postby DodgeFreak » Thu Oct 31, 2013 5:07 am
you could always put the hx exhaust housing on your h1c if you need to do it cheap. I bought a 16cm housing with the elbow for 50 bucks shipped.
