90cumminscoal wrote:Ok thanks. Now on the s300 turbo what's different on the install?
What's case pressure and how do you check it?
90cumminscoal wrote:Yes w/m kit. And I thought about jumping a tooth but didn't know if I was to that point yet. That gov spring is pretty high ain't it? And what valve springs to go with, should I do the exhaust and intake the same?
