He 351 spring gate ideas
Postby 92cummins89 » Wed Nov 20, 2013 8:55 am
Just like I said lookin for ideas and specs to make a spring gate on an he 351
Was wondering if u can weld on the exhaust housing or is it made of castiron
92cummins89
Re: He 351 spring gate ideas
Postby skilletky » Wed Nov 20, 2013 11:37 am
they are cast, but you can weld on them. i used a millermatic 210 mig welder to weld a HX40 exhaust flange onto my HX35 exhaust housing. so far its held up. i used a torch to heat the parts up before i started welding things together. i am not a good welder by no means, so someone with more experiance may have a different opinion.
skilletky
Postby DMan1198 » Wed Nov 20, 2013 2:42 pm
As long you you heat up the cast iron and don't let it cool too fast you're good to weld it. Just take your time and have an acetylene torch handy
Postby 92cummins89 » Wed Nov 20, 2013 5:41 pm
Wat bout the spring any ideas
92cummins89
Postby DMan1198 » Wed Nov 20, 2013 8:30 pm
Take the part with the female threads and get a bolt that fits it. The spring gate I have is light enough I can compress it, but it does take some effort. Then a piece of tubing that the spring goes into and that should be all the ingredients
Postby cubedeficient64 » Fri Nov 22, 2013 8:53 pm
You can use cast welding rods ( higher nickel content from memory?)with a normal stick welder. Pre and post heat and another trick is to get 2 bags of lime from your local ag store, put one bag in a steel bucket/box, do the welding job and when finished post heating drop it in the box and pour the other bag of lime over top. Pack it down and cover, leave it for a day or two to cool real slow and she will come up nice. Never had a problem doing it this way so far.
cubedeficient64
