TURBO LAG
TURBO LAG
Postby OLDEARL93 » Mon Nov 19, 2007 12:11 am
93 DODGE STOCK TURBO 21 MM HOUSING IS ANY BODY FAMILIAR WITH THESE TURBOS AN IS THERE A LAG OR IS MY INTERCOOLER THE PROBLEM
OLDEARL93
Postby wannadiesel » Mon Nov 19, 2007 10:38 am
Uh, yeah, there's a pretty bad lag when they are stock.
Best dyno: 408/844
wannadiesel
diesel guru
Postby Paccool » Mon Nov 19, 2007 2:31 pm
The housing on a 93 should be a 18.5, not a 21??
Stan
93 D250, PDR cam,stage 2 head w/o-rings,twin turbos HX35 on top HT3B on the bottom,modified IP,piston lift pump,DDP stage 3 injectors,gauges,ATS ported manifold,4" exhaust,5" inlet system,oversized intercooler, rear sway bar, fresh paint
Paccool
Postby RumbleFish » Mon Nov 19, 2007 4:38 pm
I drove a 93 last week with a 21. I could take a nap before it spooled.
Postby gear jammer 91" » Tue Nov 20, 2007 3:02 pm
You definatly need to upgrade the turbine housing on your turbo or get a new turbo altogether. I put a 16cm2 turbine housing on mine, i got it from TST. It works pretty good but their is still some lag, If you really want to get rid of the turbo lag you should get a hx35, or a wh1e, off of a second gen.
01 LB7
gear jammer 91"
