Where to find replacement fan?
Postby vwkaferman » Wed Jan 15, 2014 10:01 am
Last year had a knucklehead turn left in front of me, hit him, he took off. Pushed radiator into fan, bent one blade.
I'm afraid of bending it back, don't want it to be out of balance and perhaps grenade a bearing, so, anywhere I can find a replacement fan? Or is it the same fan as the 5.9 gasser?
Thanks in advance,
James
vwkaferman
Re: Where to find replacement fan?
Postby Black93 » Wed Jan 15, 2014 1:56 pm
You can still get a fan through the dealer. I replaced mine along with the clutch a few years ago. Seems like the fan was around $60 online. I think I still have mine if you want a used one.
Black93
Postby vwkaferman » Tue Jan 28, 2014 9:03 am
Hmm, dealer didn't have the fan. Thought I found it online through http://www.moparpartsoverstock.com/ but just got an email from them this morning saying it's no longer available.
Anyone have any other ideas on sourcing a fan? Part # 52028653?
James
vwkaferman
