What year water pump interchange.I think i got the wrong one
Postby flashgordon » Mon Nov 19, 2007 7:11 pm
...............My water pump decided to pee antifreeze on my flour to day. Got a mopar reman water pump to day and when to install it and found, well some differences.....Do you now if they interchange or have i got the wrong water pump????
How about a Internet site that i can cross reference this number?
The water pump #### is R5003665AA
http://i125.photobucket.com/albums/p58/ ... C01724.jpg
http://i125.photobucket.com/albums/p58/ ... C01723.jpg
http://i125.photobucket.com/albums/p58/ ... C01722.jpg
Any help would be gately appriseated.
Flash.
flashgordon
Postby KTA » Tue Nov 20, 2007 9:12 am
The shrouded impeller style will work no problems.
Postby flashgordon » Tue Nov 20, 2007 3:29 pm
KTA wrote:The shrouded impeller style will work no problems.
Thanks, it's in and no leakeeee :lol:
Will see if there is any better cooling affect tomorrow.
thank again for the response.
So i guess the water pump made it 220,000..........Not bad :thumleft:
Flash.
flashgordon
Postby PToombs » Tue Nov 20, 2007 6:38 pm
Mines at 208, not worried yet! ;)
Postby flashgordon » Mon Nov 26, 2007 2:14 pm
PToombs wrote:Mines at 208, not worried yet! ;)
Just came back from a 650 mile trip. no problem and no over heating either.....................But then again, the hottest temp i had to go thru was probably 65*F :sunny:
Flash.
flashgordon
