best buy
best buy
Postby Power Ram Man » Tue Nov 20, 2007 6:52 am
i was wondering where the best buy for POD or bullydog injectors would be
92 3/4 Cummins with coverted getrag 5 speed, 4x4 PODS,3200 Gov spring,16cm housing, 4inch exhuast homemade downpipe, water meth,hx35 turbo,5 inch stainless intake with AFE filter, fuel turned up, timing bumped boost,pyro guages, Denny T fuel pin,coolertubz,piston lift pump
Power Ram Man
Postby gear jammer 91" » Mon Dec 17, 2007 10:11 pm
The cheapest way to get them would to find a used set in the classified ads on this site or
http://www.dieseltruckresource.com/
http://www.cumminsforum.com/
For new ones try
http://www.puredieselpower.com/catalog/ ... 29_69.html
http://www.neweradiesel.com/node/4
Their is a hole lot more out their, you just have to have the time and the patience to look. ;)
01 LB7
gear jammer 91"
