Engine knock ??
Engine knock ??
Postby cummins32 » Mon Feb 10, 2014 4:26 pm
I've been hearing this strange knock, to me it doesn't sound deep enough to be a bottom end knock really, but that's where it seems to be coming from sort of. I have heard it for a little while and it seems worse when the truck is cold, but once it's warmed up it seems to go away. I only hear it going down the road though. it increases with rpm. I have an airdog so the stock lift pump isn't it. I've checked oil pressure before and at an idle when it was cold it was around 70psi I think, it's been awhile. Today it seemed like I could hear it very faintly when it was idling but it was very hard to hear. Then when I lifted up the boot around the 4x4 shifter I could hear it better. I put it in park and got under the truck and put my hand on everything and couldn't feel it or hear it, I can only hear it from inside the cab. I'm stumped, my next step is to cut open the oil filter. Also I put a new rear main seal in it, in november and checked the flex plate for cracks and didn't see any then. Truck has 206k on it, I change oil every 3-5k miles, When I bought it, it had 192k on it.
Diamond eye 4 inch turbo back, Glowshift boost, egt, oil pressure,hx35 , 3200 rpm spring, full power screw 2 turns, denny T II fuel pin, Home made Cold air intake, Alto reds and tci TC in a 518, 5x12's from diesel auto power.
cummins32
Re: Engine knock ??
Postby JimmieD » Mon Feb 10, 2014 4:47 pm
You have to be REAL CAREFUL DOING THIS, PLEASE! But you can either use a long screwdriver or a piece of 3/8"+ rubber tubing for a stethoscope. One end by your ear, other end placed against various components. If you're real stupid while doing it you can puncture an ear drum or get the stethoscope piece rammed in your brain etc when it gets tangled in belts. Safest is the rubber tubing because you can wrap some tape around the end if necessary to build it up so it can't fit into your ear, just against it. 3/8"+ rubber tubing should be too large to fit in ear anyway, only against. Please be careful...
1967 Dodge D-100 Town Wagon - CPL 858 4BT, HTT Stage II/H1C 16cm/56cm turbo, '93 CTD I/C, 32K spring, minor fuel tweaks, milled head, NV4500, 1 ton springs, '72 D-200 Frt. axle w/ Air Lift bags, 4.10 Dana 60HD, F/R swaybars, Tom Woods shaft.
'90 W-350 gasser...
JimmieD
Re: Engine knock ??
Postby tim curran » Mon Feb 10, 2014 7:59 pm
Your flex. Plate is cracked were the bolts mount to the crank shaft. My was doing this it got louder and louder. Drove me nuts
1993 w250, 3200 RPM springs, maxed fuel screw, industrial inj. Fuel pin, Dynamite diesel 75 horse inj., ind inj stage 2 pump, 60 lbs valve springs, ARP head studs, Banks ram air intake. 4 inch diamond eye exhaust,16cm turbo housing, 60 mm comp. Housing, BD tourqe converter, billet flex plate, Banks gauges, 212hp 608 tourque, old smokey and worn out.
tim curran
Re: Engine knock ??
Postby cummins32 » Mon Feb 10, 2014 8:35 pm
I'll have to check it out, I would rather it be the flexplate than anything else lol, I'm pretty good at pulling the trans. Anyway to actually tell for sure it's the flexplate ?
cummins32
Re: Engine knock ??
Postby tim curran » Mon Feb 10, 2014 10:19 pm
Does the noise change pitch at all from forward to reverse does it get louder when it warms up .
tim curran
Re: Engine knock ??
Postby cummins32 » Tue Feb 11, 2014 7:11 am
I don't hear the knock in reverse, but it does make another noise that's hard to explain.
cummins32
Re: Engine knock ??
Postby tim curran » Tue Feb 11, 2014 10:26 am
Time for a flex plate
tim curran
Re: Engine knock ??
Postby cummins32 » Tue Feb 11, 2014 2:13 pm
Sweet deal lol, 275 bucks for a laminated one. I read over on comp d that a billet one doesn't flex, and they said to get a laminated one.
cummins32
Re: Engine knock ??
Postby cmann250 » Tue Feb 11, 2014 2:31 pm
cummins32 wrote:Sweet deal lol, 275 bucks for a laminated one. I read over on comp d that a billet one doesn't flex, and they said to get a laminated one.
If you're a cheap azz (all the real 1st gen owners are :lol:), the 6.7L flex plate is the one to have. I'm on the hunt for one now, as I sure think I tore up the stock one I have now.
Re: Engine knock ??
Postby tim curran » Tue Feb 11, 2014 8:49 pm
I just put the billet one in my truck four hundred bucks it is .25 inches thick. One rugged bitch
tim curran
Re: Engine knock ??
Postby cummins32 » Tue Feb 11, 2014 9:47 pm
Sweet, I'll keep an eye out for one and let ya know.
cummins32
Re: Engine knock ??
Postby cummins32 » Tue Feb 11, 2014 9:50 pm
I looked on patc for a laminated one and it says 89-2014 cummins, but it says only use with a lockup trans ? Does it matter
cummins32
Re: Engine knock ??
Postby cmann250 » Wed Feb 12, 2014 4:47 am
The converter needs some room to move back and forth in there to account for expansion, sudden loading, the 'flex' of the flex plate, etc. Maybe the measurement stack up doesn't give the correct amount of space with a non locking converter. It never hurts to call and ask.
Re: Engine knock ??
Postby Tacoclaw » Wed Feb 12, 2014 6:17 am
Mark Nixon seems to have a couple 6.7's hanging around his place judging from his posts over there, it couldn't hurt to give him a call and see. His number is in his sig on CompD.
Re: Engine knock ??
Postby cmann250 » Wed Feb 12, 2014 3:10 pm
Tacoclaw wrote:Mark Nixon seems to have a couple 6.7's hanging around his place judging from his posts over there, it couldn't hurt to give him a call and see. His number is in his sig on CompD.
Yea I talk with him fairly regularly. I found a 2nd gen 12v flex plate locally for free.99 and that's a hard deal to pass up.
