Starting issue
Starting issue
Postby mitchk » Mon Mar 24, 2014 1:21 pm
So ive been chasing this problem for about a month or so now. It first started when i drilled the banjo bolts and then needed a new lp. after the lp something happened and now it doesnt want to start. It was worse but its slowly gotten better from trying to find out the problem. It started off not wanting to start at all unless i gave it some throttle. Didint matter how long it had been sitting since running. Now after sitting the night it just takes a few cranks and then fires and sometimes it will kinda stutter a sec or two after it starts then it will smooth out and be perfectly fine. also if im running around town and need to shut it off for a short period it starts fine, first turn of the key fires but it will still stutter and then be fine. Ive gone over all the lines from the lp to the injection pump because i was told it was caused by air being allowed into the lines letting fuel drain back to the pump and losing prime. I ordered the drilled banjo bolt from RC along with a pressure guage because the original bolt had a small nick in it pretty close to where the seal sat and i thought that was the problem. got the new banjo bolt in and the guage in and drove it. didnt seem to different and i let it sit overnight and same thing. It just cranks acouple times then starts. dont know what the problem is, i had the lines off from the outlet of the lp to the inlet on the injection pump yesterday and it all looks fine, nothing out of the ordinary, no little scratches or anything that would possibly let air by. the pressure guage also sits right under 15psi at idle, probly around 13 or so. It also doesnt hold pressure after the engine is shut off, dont know if it should or not. Just miss when it would start by just thinking of turning the key (couldnt even tell there was a starter down there). know its like a friggin powerstroke cranking over a bunch before it starts up. Thanks for any help, Mitch.
Daily: 91 d350 727 gear vendors over drive, 3/8 feed line, THD lplp, maxed pump, Denny t 2, timing to head, #366 spring, 60# valve springs, arp studs, 60 horse injectors?(po), THD bahf, s362sxe
Project: 93 w250 5 speed, ground stock pin, #366 spring, 60# valve springs, THD lplp, intercooled compressor non intercooled turbine, diamond eye 4 inch, custom intake, south bend hd single
mitchk
Re: Starting issue
Postby RCCUMMINS89 » Mon Mar 24, 2014 3:12 pm
Subscribing so that I read this more in depth later when I have time.
Re: Starting issue
Postby JimmieD » Wed Mar 26, 2014 7:27 pm
I usually suggest adding in between 6" and 12" of clear vinyl tubing at end of fuel line right before your filter. Gives an easy way to eyeball things and check for air, contaminants in fuel or water, without having to take anything apart to do so each time. I use common hardware store clear plastic tubing, has been working about 7 years so far.
1967 Dodge D-100 Town Wagon - CPL 858 4BT, HTT Stage II/H1C 16cm/56cm turbo, '93 CTD I/C, 32K spring, minor fuel tweaks, milled head, NV4500, 1 ton springs, '72 D-200 Frt. axle w/ Air Lift bags, 4.10 Dana 60HD, F/R swaybars, Tom Woods shaft.
'90 W-350 gasser...
JimmieD
Re: Starting issue
Postby mitchk » Sat Mar 29, 2014 7:34 am
I dont know if this will help any but this is what it does after sitting the night.
I just cant track down where this leak is coming from. doesnt leak fuel from anywhere but as soon as the motor stops running the fuel pressure gradually drops to zero on the guage but holds fine while running. Was thinking of putting some soap and water on all the fittings just to see if i can see some bubbles or something.
Also, little confused on what you were saying with the clear tubing JimmieD. Where do you connect each end seeing as the line has the hole for the banjo bolt and theres nothing on the motor to attach to. mabey im just over thinking it or not thinking enough but i was a little confused on that. Thanks for the help though
mitchk
Re: Starting issue
Postby PToombs » Sat Mar 29, 2014 4:21 pm
If that's a video it didn't play for me, appears to be a pic. It's normal for the fuel pressure to drop after the engine quits, it takes a few seconds for mine to drop. It just bleeds off thru the IP and LP.
Jimmie meant to add the clear tubing in the line just before the lift pump. Then, if it is sucking air from the tank to the LP, it will show the air bubbles in the fuel flow.
