Valve adjustment
Valve adjustment
Postby brandonmgreer » Tue Apr 22, 2014 8:31 am
What is the interval on adjusting the valves on these engines? Mine is running just the tiniest bit rough, and I'm thinking the valves may have never been adjusted in 300k miles... just a thought
White/black 92 D250 manual conversion, Pump tweaking is about it right now...
95 CCLB 4X4 5 speed being but back together from a wreck
99 Kenworth W900 flat top, Tuned 500 Detroit, BW 75mm 1.32A/R, 5915 injectors, 13 speed, 3.55's
brandonmgreer
Re: Valve adjustment
Postby RCCUMMINS89 » Tue Apr 22, 2014 8:44 am
Every 50k? IIRC... either way, if you've never done it... get 'er done.
.010 intake, .020 exhaust.... I run mine at 8 and 18 though.
Postby ellis93 » Tue Apr 22, 2014 8:51 am
Supposedly every 36k.
Postby skilletky » Wed Apr 23, 2014 10:43 am
i check/set mine every 6 months, or when ever i have the valve covers off. i set mine at 8 and 18 also, on both of my trucks.
skilletky
Postby autocar56 » Wed Apr 23, 2014 7:29 pm
When you do set them and you use the timing pin, mark the harmonic balancer to to block somewhere that way the next time you don't have to worry about using the timing pin to find tdc. Its kind of a pain to bar the engine over and and push the pin in.
91.5 4x4,5 speed, pump timing 1/16, fuel screw 1 turn, ground down pin, k/n air filter , stacks, 160,000 miles
autocar56
Postby RCCUMMINS89 » Wed Apr 23, 2014 7:46 pm
I've always just gone off from number 6. When the valves are at cross over, you are a tdc.
Postby brandonmgreer » Mon Apr 28, 2014 9:18 pm
Sorry for the delayed response, and thank y'all for the input and suggestions.
Are there any benefits to running them at .8 & .18 over .10 & .20?
Will the valve cover gaskets seal back up or do I need to have new ones on hand when I do it?
brandonmgreer
Postby RCCUMMINS89 » Mon Apr 28, 2014 10:14 pm
If the valve covers are fresh, you can re use them... if it has been a while, they'll most likely need replaced.
The advantage of the 8 and 18 are a little more air, in and out. Is it noticeable? Figure it can't hurt and many cam guys have said it wasn't a bad idea.
