coolant temp sensor location
Postby muddpar » Thu May 01, 2014 3:37 pm
when I first bought my 92 Cummins it had a aftermarket coolant temperature sensor, located in the front of the engine by the thermostat. I run electric fans and that sensor is located where stock should be. The electric fans should turn on at 195℉ but they turn on at or over 210℉. The thermostat in the truck is 180℉. So my question is location the problem or do I have a bad sensor. Would switch in the sensors fix the problem. the engines is in a 93 Chevy so I can't run the stock fan, no room for it without a body lift. The gage in the truck stock Chevy.
93 chevy k3500 dually with a 92 Cummins 4l80e, 4.10 gears Aurora 3000, lppp, ps intercooler, cooler tubz
92 chevy c3500 dually 6.5l turbo diesel
93 dodge w250 360 mpi plow truck
85 dodge 2.5 ton 440 on 57" tractor tires
57 dodge d400 inline flathead maybe future Cummins
95 dodge incrapid 3.5l daily driver
muddpar
Re: coolant temp sensor location
Postby ByronRACE » Fri May 02, 2014 7:37 pm
Use an IR temp gun and an ohm meter. Suspend the sensor over a pot of water on the cook top, monitor temperature, and see when it turns on. That will tell you if the sensor is bad or not.
ByronRACE
Postby dazedandconfused » Sat May 03, 2014 4:21 am
I believe the stock temp sensor location is in the side of the head at the rear of cylinder 6. That's where mine is anyway.
