Intercooling a a stock 90 Non Intercooled truck
Postby JeffTheMarine » Mon May 26, 2014 10:19 am
I am looking for some options into intercooling my truck. I have a 90 Non intercooled D250. I am not wanting to change to the intercooled style grill. I plan to add a Snow water methanol injection system regardless. Should that be enough with a 4inch straight pipe exhaust to keep it cool or am I going to need something else like an air to air intercooler? I have looked at some of the stuff to add a air to water setup and honestly it seems like more of a hassle than it is worth. I also have the ability to make my own crossover tube and was thinking of making a full 3 inch crossover with bungs welded for the injection and my boost gauge. If I run a 4inch exhaust and a full 3inch crossover will that be enough for pulling to keep it cool? Trailers and such. I don't plan to do any sled pulling at all.
Jeff
1981 Dodge W250 Crew W/94 12V&NV4500+NP205
Mods: Ground #100Plate,AFC Foot ground,BHAF
1990 Dodge D250 NonIC 12V Smoke screw flush,Fuel pin turned, Star wheel bottomed -5 clicks, fuel screw in 1 extra turn
JeffTheMarine
Re: Intercooling a a stock 90 Non Intercooled truck
Postby RCCUMMINS89 » Mon May 26, 2014 8:40 pm
It solely depends on your fueling and air mods....
What turbo and injectors do you plan on running? How much do you plan on turning up the pump?
Postby JeffTheMarine » Mon May 26, 2014 8:58 pm
Well I was thinking of running a 54mm H1c that came on the intercooled trucks along with the 18.5cm or possibly a 16cm exhaust housing. I kind of figured the stock non ic larger injectors would be enough for what I am wanting. All in all somewhere around 300 or 350hp is what I was thinking. The main thing is I don't want to change the grill because that is my favorite style of grill for this body style of truck.
Jeff
JeffTheMarine
Postby RCCUMMINS89 » Mon May 26, 2014 9:30 pm
At 300-350 hp with an H1C, you'll need an intercooler.
Go with a 2nd gen or power stroke intercooler and you can keep your factory grill.
Postby oldcool90 » Tue May 27, 2014 5:15 am
If you don't mind getting rid of your ac condensing coil its very easy to install a first gen intercooler with no cutting up of that style grill.
oldcool90
