What Will This Hurt?????
Postby CumminsPride » Thu Nov 29, 2007 12:24 pm
Well I had swapped out my home ground pin a while back for a buddy's stocker and he doesn't want to give it back. This left me with no choice but to grind a new one. Today while home at lunch I decided to do just that and had what I thought to be a GENIUS IDEA! But not too sure of it's longevity(that's why I am starting this thread). What if I remove the pin from the diaphram and use just the rubber to seal the pump top, then proceed to plug the boost reference line and the block?? This will ensure full fuel correct?? Will it damage the IP?? Will the pin fall into the hole where the fuel cone was??
Wade
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby gman07 » Thu Nov 29, 2007 12:55 pm
I think doing that would cause the little pin to come out too far and leak fuel into the AFC housing; the fuel would then leak out the back vent in the housing. Removing the AFC lever would do the same thing for power.
1992.5 W250 pump tweaked, straight pipe, gauges, 3200 Gov. spring, AFC lever partially ground, timed at 1/8", Fuel pin ground, BHAF, HTT Stage IV H1C/E 60/12wg (ported), Transgo shift kit, KDP clothes-hangered, 202,000 miles - 36psi, 1250°
gman07
Postby cummins king » Thu Nov 29, 2007 4:31 pm
ya just remove the afc lever and you will have fuel fuel or go to your local pump guy and get an agraculture pump top
93 4X4 auto
cummins king
Postby hassy21 » Fri Nov 30, 2007 12:22 am
I did that same thing but how do you fix the leaking from the vent on the afc housing.
hassy21
Postby cummins king » Fri Nov 30, 2007 5:46 am
well im geussing you punch the afc lever out, what i did was just break the tab off, and that wont cause it to leak, i think your going to JB weld it on the out side so it will stop leaking
93 4X4 auto
cummins king
Postby CumminsPride » Fri Nov 30, 2007 6:10 am
Well I know that it will leak! Just had to try! I also believe that that vent fitting should back out of the housing. I think it can be tapped and plugged, then reinserted. At least I hope so.
Wade
CumminsPride
Postby CumminsPride » Fri Nov 30, 2007 10:55 am
Yes the vent backs right out with a 17mm deepwell and a 6" extension!!! You can tap the inside with a 6-32 tap(without predrilling). I used a electrical outlet cover screw with a dab of The Right Stuff inserted before the screw. Also used The Right Stuff to make a gasket for the top of the housing. Plugged the boost port with a schrader valve for future testing!!
So I had to road test the beast and this was fun at first. After about 5 minutes of romping I decided to do a boosted launch at 10psi and she decided to just rev :oops: . Trans is shot. Now I have very spongy forward gears and a good reverse. :lol: Oh well I knew this day would come.
Wade
CumminsPride
Postby hassy21 » Fri Nov 30, 2007 11:41 am
my tranny has gotten so bad that I cant even get half throttle from a dead stop without the tranny slipping. Even cruising at 60mph abd I nail it will slip in 3rd. But soon I will be getting my tranny rebuilt or put the 47rh in.
hassy21
Postby CumminsPride » Fri Nov 30, 2007 12:23 pm
Where are you located Hassy? I just talked to a guy here about mine and he suggested building a full race 727. He might have some good insight.
Wade
CumminsPride
Postby hassy21 » Sat Dec 01, 2007 4:26 am
im from central california
hassy21
Postby CumminsPride » Sat Dec 01, 2007 5:25 am
Well never mind then. You may as well be in China. LOL
Wade
CumminsPride
Postby dpuckett » Fri Dec 07, 2007 5:30 pm
Make sure your local guy knows diesels and diesel transmissions. The torque curve is totally different, and thus are the internals needed to transfer the torque to the ground. Most gasser trannies have a HIGHER than stock stall speed. Stock stall speed for the diesel is already 200rpm too high.
Daniel
