oldestof11 wrote:How much smoke are we talking? A puff is unavoidable. It will be at full fuel because the gov isn't spinning to even out the spring tension.
cmann250 wrote:As per the owner's manual, start it at part throttle. I've done that and pretty much instantly let off the throttle. It doesn't smoke near as much.
RCCUMMINS89 wrote:AFC lever adjustment has some control over it. If you put a lot longer slide pin in, and a super fat fuel pin (conservative low end)... it'll tame it down a lot. With my big ol' injectors, my initial "puff" is less than my ol' man's bone stock non I/c truck puts out.
DodgeFreak wrote:cmann250 wrote:As per the owner's manual, start it at part throttle. I've done that and pretty much instantly let off the throttle. It doesn't smoke near as much.
Yeah, that doesn't help, only thing it does is push the heavy smoke out faster
cmann250 wrote:DodgeFreak wrote:cmann250 wrote:As per the owner's manual, start it at part throttle. I've done that and pretty much instantly let off the throttle. It doesn't smoke near as much.
I tried that again and you are correct, it makes it worse if anything.
