So with the truck I bought it came with a manual and I hadn't thought to look at it untill replacing the front and real seals and the oil pan gaskets and guess what, it doesn't have the torques for the bolts.
Anyways, could someone please tell me:
Rear main seal bolt torque
Oil pan bolt torque
Front timing cover bolt torque
Timing housing to block torque
PToombs told me I should double check the torque of the bolts that hold the housing to the motor since I am going to be in there.
Thanks guys and my manual will be on order.
Oh this is an 1989 5.9
Matt
