by RCCUMMINS89 » Sat Jul 26, 2014 7:06 pm
Are the 1st gen and 2nd gen timing pins the same?
89 RC on shortened 92 diesel frame - NV4500 w/dual disc/4.10s on 37s. - Self built pump, "hot screw", lots of timing, True high volume low pressure lift pump, 62fmw/68/.7gated, 77lpm SAC Inj., Studs/O-rings,- 423/1220 Mustang - 11/16/2013
http://www.TheHungryDiesel.com full line dealer, if you don't see it please ask.
