Medium locktite or RTV on cover bolts ?
Postby jethro » Thu Aug 28, 2014 9:51 pm
About to torque bolts on the front engine cover after KDP fix. Noticed some guides suggest RTV on bolt threads-
other say locktite. I have never used RTV on bolt threads for anti-backout. I have been using medium locktite
so far......
Opinions ??????
Tim
jethro
Re: Medium locktite or RTV on cover bolts ?
Postby DodgeFreak » Fri Aug 29, 2014 7:52 am
Locktite.
Rtv has more give to it...either one would work.
Postby ellis93 » Fri Aug 29, 2014 10:01 am
Loctite x2
FWIW that ultra grey silicone is some ridged schit when it sets up,I could see it retaining a bolt.
Postby jethro » Fri Aug 29, 2014 4:05 pm
OK- I will go with the medium locktite.
I did not know the grey RTV was firmer than the other colors..... that might be usefull to know....
Thanks for the replies....
Tim
jethro
Postby PToombs » Fri Aug 29, 2014 5:35 pm
I never use Loctite or sealant on the bolts and never have any problems.
Postby Sutter1stgen » Fri Aug 29, 2014 8:57 pm
I loctite'd my cover bolts just as I did the case bolts. I used a weaker compound, but cleaned and primed each hole just as I did the case threads. I've had some very bad luck in the past with bolts coming loose. I think I went a little over kill though. :lol:
Eric
Sutter1stgen
