I had fuel leaking from the same place, all I did to fix it was tighten up the four allen head bolts holding the hydrolic head on. They weren't actually loose I just gave them an extra 1/4 turn or so and the leak stopped. It's a lot cheaper and easier than replacing or rebuilding. . . for now.
Sold 91 now-intercooled W250, 388WHP 923WTQ on #2 only 423WHP 968WTQ on meth 0% correction. 01 LB7
If you turned them a 1/4 turn, I'd think they were loose(r) than needed.
DP
His- 93 W250 club cab LE, auto to Getrag conversion, piston lift pump, 3.54 LSD. 400k+ Hers- 04 QC 4x4. Built auto, Triple Dog, Air Dog. Funny Round truck that aint so quiet.
When reinstalling the hydraulic head, does one have to draw it up tight with the allen bolts compressing the two plunger return springs? I wasn't sure. Didn't know if I could simply push the head back into the pump case. Since it is a junk pump, I went ahead and pulled them together with the allen bolts.....
Bill Gilbert 85 D350 crew with 90 6BT intercooled Getrag 3.07's 93 D350 single cab Getrag 3.54's.
dpuckett wrote:If you turned them a 1/4 turn, I'd think they were loose(r) than needed.
DP
I had just adjusted the timing about a week before this without loosening any of the fuel lines and I think that is what caused the hydrolic head to be slightly loose.
