exh. manifold bolts ?
Postby jethro » Mon Sep 08, 2014 10:20 pm
Putting on a new exh. manifold this week end. The old bolts holding it into the block were pretty rusty and stickey-
(happy there wasn't much torque) They all came out pretty hard considering the low torque they should have been at.....
I have seen antique cars and aircraft use brass hardware on the exhaust to prevent breaking things down the road when it has to come apart again...
Also I wondered if stainless would work OK ? Not sure if I could even find metric brass bolts......
Any Opinions ? / experience ?
Tim
jethro
Re: exh. manifold bolts ?
Postby RumbleFish » Tue Sep 09, 2014 6:11 am
In, ill be doing this soon.
Postby DMan1198 » Tue Sep 09, 2014 9:53 am
Go to studs. It makes it one million times easier to install. If you can get them stainless all the better. I got mine through genos garage
Postby PToombs » Tue Sep 09, 2014 5:56 pm
I use stainless bolts and neverseize the crap out of them.
Postby ellis93 » Tue Sep 09, 2014 6:57 pm
PToombs wrote:I use stainless bolts and neverseize the crap out of them.
Huh!?!? You like drilling and removing those? :bom:
Postby PToombs » Wed Sep 10, 2014 4:32 pm
I never have a problem with them. I also think you're missing the point that I have that stuff off about once a year for something or other, putting on twins, swapping turbos, or just because I don't have enough other Shit to do in my life so I frig this up somehow.
Postby ellis93 » Wed Sep 10, 2014 5:58 pm
PToombs wrote:I never have a problem with them. I also think you're missing the point that I have that stuff off about once a year for something or other, putting on twins, swapping turbos, or just because I don't have enough other Shit to do in my life so I frig this up somehow.
Oh :lol:
Postby jethro » Wed Sep 10, 2014 7:12 pm
I was fantasizing about being able to find brass bolts in metric- put them in with a graphite/molly anti-seize
and then drill the bolt heads for safety wire so they cant loosen or back out. I guess I can do the same with stainless....
If I remember correctly - back when I drove a CJ-5 with the in-line 6 cylinder- it loved to eat intake gaskets.
it would pull them in two from the manifold expanding/contracting. I later found out that there is some kind of
"magic" goop made from molly and graphite that you put in there that allows the gasket to slide WITH the manifold
instead of going stationary on the block from friction. Apparently it did not break down from the heat involved. If I can
find out what that stuff was- that might be good on/in the bolt threads.
T
jethro
Postby PToombs » Thu Sep 11, 2014 5:08 pm
You might have better luck finding brass studs and nuts. Or regular studs and brass nuts would be better than stock stuff.
