Melted injector tips
Postby josh_6bt » Sun Oct 05, 2014 6:25 pm
Awhile back my truck runaway will I was idling down a street. I later found out my he351 blew its seals, which was what I believe caused the runaway. I just got the head off and found all but 2 injectors have the tips melted off. What would cause this? Excess oil in the combustion chamber causing a raise in temps?
1992 W250 EC, 5 speed, 3.54s, 175hp p-pump, timed @ 16.5, #100 fuel plate, 4k GSK, 5x14, .024 DV, head studs, 60lb VS, 4" exhaust, BHAF, cooler tubz.
josh_6bt
Re: Melted injector tips
Postby RCCUMMINS89 » Sun Oct 05, 2014 7:03 pm
I'm assuming the pistons were melted as well? An he351cw at runaway rpms and 7x10s would cause utter extreme heat, it could simply be the fact of things got that hot.
Do you have pictures of these things? I've never seen that before.
Postby josh_6bt » Sun Oct 05, 2014 7:15 pm
I'll get some soon. Just the edge of the bowl is melted but it looks more like it's sandblasted than melted. No holes either.
josh_6bt
Postby josh_6bt » Mon Oct 06, 2014 4:55 pm
Not the best pics but here you go. [[img][img]http://s30.postimg.org/rf72uwsu5/image.jpg[/img] Image Image Image Image Image Image [/img]
josh_6bt
Postby RCCUMMINS89 » Mon Oct 06, 2014 5:14 pm
I've personally never seen that before... but to me it simply looks like things just plain got crazy hot.
