HELP!!!! VE troubles
Postby 93MilitiaMobile » Thu Oct 16, 2014 3:44 am
Anyone know where i can get my hands on a new AFC pump top housing. I just went to reseal mine to find that someone had installed the fuel screw with what seems to be locktite.Damn screw broke at the washer and is now lodged in the housing. Gonna take it to the machine shop today but my hopes are faultering. Any help or info will be greatly appreciated.
93 W350 dually w/ sleeper cab and flatbed, 6bta 160 IC, G360, BHAF, 366 spring, H&M DTA, HungryDiesel AFC Spring, 4in exhaust, Warn hubs, 3.54's, headlight relay, Bilsteins, Pacbrake airbags, Jungles "shelf-it", LED's FUTURE MODS 60lbs valves, injectors, EX brake, Gear Vendor, remote oil filter, Mag-tec diff covers, LPG injection, dual batteries, Alt upgrade, RamCharger 2nd tank
93MilitiaMobile
Re: HELP!!!! VE troubles
Postby CumminsPower59 » Thu Oct 16, 2014 7:02 am
Sounds like someone cranked on the fuel screw a little too much. There may be enough left on the inside to get on it with vise grips, put some heat on the housing around the screw and see if it'll budge. If not, I'm sure you'll be able to drill it out, but be careful ;)
Worst comes to worst, I may have a spare pump top laying around...
Postby 93MilitiaMobile » Fri Oct 17, 2014 3:52 am
Thanks Ike, I've got it with a competent machine shop (fingers crossed). Guess I did over torque on the screw, but i had heat on it for a few hours. Measured the screw had heated to 400F clean through and no budge. I knew this was going to be an issue the first time i tried to turn it when i took the pump apart for my 366 spring, so i've had a new screw and o-ring ready and waiting. Did everything in my power, sadly a 20 year old farmer used drill press just ain't that precise. Stopped before my bit deflected to far so hopefully they can get a mill bit down there as the screw also broke on an angle....... fingers crossed. I'll let you know if i have a need for that potential top. thanks
93MilitiaMobile
Postby 93MilitiaMobile » Sat Oct 18, 2014 4:23 am
Machine shop nailed it, boy what i'd give for a mill.
93MilitiaMobile
Postby CumminsPower59 » Sat Oct 18, 2014 10:23 am
Good deal!
