Turbo issue?
Turbo issue?
Postby thrashingcows » Fri Oct 17, 2014 9:00 am
Ok a little back story before I get to the real issue... ;)
Went to go see my diff guy today...doesn't sound good. I think I have to have both front and rear diffs gone through.
Not going to be cheap...but I trust this guy, he's passionate about what he does, and has done work for me on other projects. Never a problem with his work.
But now I have to make a decision is I'm going to stay with the 4.10's or go with 3.54's. I already have a set of Dana 70 3.54 gears that I picked up super cheap...they were removed from an original truck back in 1992 when the owner wanted 4.10's instead of the 3.54's for pulling his 5th wheel.
So since I needed to make a decision on what gears I want, I thought I'd toss on my HX35 this evening. I wanted to see how my EGT's and fuel mileage might be effected by the 12cm exhaust housing and my PS intercooler, and the 4.10's.
Everything went well until I fired it up and went for a drive. The turbo sounds like it has a very tinny whine coming from somewhere. And when I got out on the road it will not build any boost. I think once I saw about 1-2lbs...that's it!
I initial just had the waste gate wired shut. But then second guessed myself and thought maybe my problem was that I had wired it in the open position. SO I removed the wire and re-installed the wastegate actuator. Went for another drive and same problem, nothing changed.
I have been reading threads on HX35's and could not come up with anything like my problem. Any idea of what the problem might be?
thrashingcows
Re: Turbo issue?
Postby oldestof11 » Fri Oct 17, 2014 9:08 am
How are the connections for the boost tube? 90* elbow tight?
Re: Turbo issue?
Postby thrashingcows » Fri Oct 17, 2014 9:34 am
oldestof11 wrote:How are the connections for the boost tube? 90* elbow tight?
Everything went together nicely, don't think so, but maybe?? But it was dark and late when I finished up last night. I'm going to head out and check things now in the light of day. Maybe there is something obvious I missed last night.
thrashingcows
Re: Turbo issue?
Postby oldestof11 » Fri Oct 17, 2014 9:43 am
The only other thing to not have boost is a locked up turbo.
Re: Turbo issue?
Postby thrashingcows » Fri Oct 17, 2014 2:00 pm
Well in the light of day it was pretty obvious what the problem was....
Tad bit of interference between the impeller and the housing..... :shock: Guess my turbo rebuilding skills still need a little work. :oops:
Now that there is wear on the intake housing, does that make the housing junk? Or if I got a new cartridge for the HX35 can I install it and be good to go?
thrashingcows
