oil pan gasket
oil pan gasket
Postby v8coupe » Fri Oct 24, 2014 12:12 am
My truck is leaking fairly bad from the oil pan gasket. Can that be changed in the truck on a 2wd?
v8coupe
Re: oil pan gasket
Postby thrashingcows » Fri Oct 24, 2014 2:55 pm
Yes, but I would not recommend it. You have to loosen the motor mounts, remove the fan and shroud, and maybe the exhaust head pipe, and then jack the motor up as high as you can get it. Even then it's a tight squeeze to get the pan off and on.
thrashingcows
Re: oil pan gasket
Postby v8coupe » Sat Oct 25, 2014 2:38 pm
thrashingcows wrote:Yes, but I would not recommend it. You have to loosen the motor mounts, remove the fan and shroud, and maybe the exhaust head pipe, and then jack the motor up as high as you can get it. Even then it's a tight squeeze to get the pan off and on.
sounds like a good thing to do when I do the Manual swap then, noted.
v8coupe
