PODS
PODS
Postby Power Ram Man » Fri Dec 07, 2007 6:49 am
i was wondering how much power i would have (estimate) once i put POD injectors in my truck and if it is ok to put pods in my truck with the mods i have already done.
92 3/4 Cummins with coverted getrag 5 speed, 4x4 PODS,3200 Gov spring,16cm housing, 4inch exhuast homemade downpipe, water meth,hx35 turbo,5 inch stainless intake with AFE filter, fuel turned up, timing bumped boost,pyro guages, Denny T fuel pin,coolertubz,piston lift pump
Power Ram Man
Postby cummins king » Fri Dec 07, 2007 3:15 pm
you will gain about 40 hp with 80 ft of torgue, but it will smoke like crazzy because there not very efficiant
93 4X4 auto
cummins king
Postby TWorline » Fri Dec 07, 2007 6:05 pm
You might get a few more HP with 'em Dixie horns! ;)
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby Begle1 » Fri Dec 07, 2007 6:43 pm
TWorline wrote:You might get a few more HP with 'em Dixie horns! ;)
Are Dixie horns worth more than turkey horns?
Postby ford69557ci » Fri Dec 07, 2007 6:55 pm
spend just a few more bucks and get some 370's or 435's. cleaner more useable power an the smoke is alot more contollable
ford69557ci
Postby bgilbert » Fri Dec 07, 2007 6:55 pm
POD's are advertised as +60hp +90ftlbs at the wheels.
Bill Gilbert
bgilbert
Postby cummins king » Fri Dec 07, 2007 7:50 pm
i guess its the typ of truck i know that non ic will only get 20hp and 50ftp
93 4X4 auto
cummins king
Postby bgilbert » Fri Dec 07, 2007 7:59 pm
Yeah I should've stated that was for an IC'd truck. You'll still need the airflow and fuel supply to get those numbers.
bgilbert
Postby Power Ram Man » Mon Dec 17, 2007 6:26 am
thanks for all the replys the reason i wanted pods is becuase of smoke i want as much of it as possible i know that smoke is not nessasaraly good but i like it like i say if you cant beat em smoke em out ;)
yea the dixie horns did give me a few extra horses :lol:
Power Ram Man
Postby cummins king » Mon Dec 17, 2007 9:28 am
then get the pods :lol:
my bodys got a set and he can smoke out three lanes of trafic its not very nice to drive behind him lol :) :lol:
93 4X4 auto
cummins king
Postby ford69557ci » Mon Dec 17, 2007 4:56 pm
if ya really want smoke get a set of custom edm's some 6x 20's will make cars pull over lol
ford69557ci
Postby cummins king » Mon Dec 17, 2007 6:17 pm
oh remove the afc leaver to that will really help with the fuel, and also get a automatic 21cm housing and watch out, smoke hugh, who blocked out the sun, lol :lol:
93 4X4 auto
cummins king
Postby Power Ram Man » Tue Dec 18, 2007 6:09 am
thanks for all the replys the guy how is putting in the pods says i will have an estimated 250hp that is including the 3200 govoner spring which he is also putting on my truck does this sound like a good estimate?
Power Ram Man
Postby dpuckett » Tue Dec 18, 2007 11:26 am
It's a good estimate if your pump has been turned up some. If it is still completely stock, 200-220 is about right.
DP
Postby Power Ram Man » Tue Dec 18, 2007 6:32 pm
yea pumped turned up as much as possible
Power Ram Man
