Engine noises caused by injector issues.
Postby ellis93 » Wed Nov 26, 2014 5:46 pm
What's some of the ones yall have heard of? Just hearsay or whatever.
I'm having some weirdo,coming and going noises in the 82s engine and I have checked nearly everything I know of than just striping it down.
Re: Engine noises caused by injector issues.
Postby RCCUMMINS89 » Wed Nov 26, 2014 6:07 pm
Hardcore rattle... sounds like a ruler slapping a desk randomly (CR are notorious for this one)... Loud ticking/knocking. Tappet sounds...
Postby ellis93 » Wed Nov 26, 2014 6:24 pm
Yep all of the above. Idle to like two gs,it will tap.....randomly,not always. Every time you hit 24 or 2500 is real loud. Funny thing is I never noticed the high rpm rattle/knocking till I did the 4k gov springs. The light tapping has been there since a few months ago tho.....least to my memory.
Postby RCCUMMINS89 » Wed Nov 26, 2014 7:05 pm
Sounds like it might be simply a timing thing..
Postby ellis93 » Wed Nov 26, 2014 7:21 pm
18* on the money with the tooling,checked that today for giggle. That every now and again crap has me wanting to fast forward to the 7x10s quicker than I wanted.
Postby RCCUMMINS89 » Wed Nov 26, 2014 7:50 pm
If the timing is JUST RIGHT.... I've noticed a 12 valve can sound like it has bad injectors. Mine at certain timing/load sounds like it has leaking injectors. Advance or retard timing, and it goes away.
Postby ellis93 » Wed Nov 26, 2014 7:56 pm
Wonder if I may have fubar'd the flex plate and that is what the high rpm crap is :scratch:
Looks like I'll be trying out my injector pop tester this weekend.
Postby cmann250 » Thu Nov 27, 2014 6:25 am
ellis93 wrote:Wonder if I may have fubar'd the flex plate and that is what the high rpm crap is :scratch:
When I ballooned my converter and screwed up the flex plate, I could have sworn it was top end noise
Postby ellis93 » Thu Nov 27, 2014 7:48 am
That's good to know Caleb. The converter in there has a billet cover and solid bolt ring and should not be ballooning,it is mine tho. I'll keep this in mind.
