5.9 won't start after rebuild
Postby wilkyflex » Sun Dec 21, 2014 1:28 pm
Hey guys, just did a complete rebuild on my 5.9 cummins engine. It won't start. Here's a video showing what happens.
https://www.youtube.com/watch?v=23TiSNs ... e=youtu.be
I don't know why it won't start. Can you help?
I thought I was very careful about the timing when assembling it. Locked the injection pump at TDC and removed it and put it back the same way.
Aligned the "0" on the crank to the "0 0" on the camshaft at TDC with pin inserted, then put the injection pump drive gear back in the same place aligning to letter E. Can anyone give me any ideas.
It just doesn't fire at all even though it is getting fuel. The only time it ever fired during a start attempt was when I sprayed carb cleaner in the intake, and it would only fire once or twice. It has never tried to start or fire on any of the cylinders without spray in the intake.
wilkyflex
Re: 5.9 won't start after rebuild
Postby RCCUMMINS89 » Sun Dec 21, 2014 7:26 pm
Double check the keyway.
Postby ellis93 » Sun Dec 21, 2014 8:29 pm
RCCUMMINS89 wrote:Double check the keyway.
Ditto
Postby wilkyflex » Sun Dec 21, 2014 10:56 pm
check the keyway? You mean check the keyway of the injection pump, that the key is in the right place? Or the camshaft? Not sure what you mean?
Thank you
wilkyflex
Postby RCCUMMINS89 » Sun Dec 21, 2014 11:10 pm
Make sure it is in its place in the injection pump
Postby wilkyflex » Mon Dec 22, 2014 12:15 am
ok, thank you. I will. I was very careful when putting it in, so I visually looked at the key to make sure it was in there properly. But it won't hurt to check it again. Any other ideas?
Thanks
wilkyflex
Postby wilkyflex » Tue Dec 23, 2014 12:54 am
Here's the solution guys. I'm such a dummy. watch this:
https://www.youtube.com/watch?v=UoMt7QU ... BK5sBDpu1g
wilkyflex
Postby PToombs » Tue Dec 23, 2014 7:44 pm
Well, at least the timing was advanced for a cold start! :lol: Glad it was something simple for you, it sounds good.
