fuel pumps
fuel pumps
Postby odee » Tue Jan 20, 2015 8:23 pm
guys have gotten a good used raptor rp 100 fuel pump for my gmc/6bt conversion. What would be the best way to use this pump in a dual tank setup? How is the best way to make fuel pick ups in the tanks?
odee
Re: fuel pumps
Postby RCCUMMINS89 » Wed Jan 21, 2015 5:28 pm
What are the factory pick ups in those tanks
Re: fuel pumps
Postby DMan1198 » Wed Jan 21, 2015 6:29 pm
Since my 80 has dual tanks I put some thought into plumbing them. I'll be putting a sump in each, and running 1/2" line into the raptor 100 I've got then into a dual filter setup before it gets to the ip. Now either I'll just run a Y block and let it feed from both tanks at once or use some kind of diverter (likely mechanical so I can use the existing push-pull knob) I'll have to look and see if anyone makes the diverter I'm after
Re: fuel pumps
Postby odee » Tue Mar 31, 2015 4:19 am
the tanks have a 3/8's pick up that the float is mounted on. Have been thinking about a sump but truck is 2wd don't want to drag it off. How well do the draw straws work with this style pump? Will the 100 have to much pressure for the ve pump?
odee
Re: fuel pumps
Postby 93DodgeCummins » Tue Mar 31, 2015 7:30 am
The raptor should have a pressure adjustment so your can set it to your desired pressure
93 Dodge W250 4X4, Custom air intake, Diamond Eye 4 inch turbo back straight pipe exhaust, HX-35W with Banks upgrades, KDP fixed, Getrag 5 speed, Isspro Tach, pyro, fuel pressure, and boost. Raptor 150, 3200 rpm spring, Power Screw in 1 turn, aftermarket fuel pin
93DodgeCummins
