1989 dodge w350 missing under load
Postby manostihl » Wed Jan 21, 2015 12:56 am
my 1989 w350 just started missing under load or rather when chugging it and short shifting you can hear it and it shakes, but when you rev it out in neutral or its idling it seems to run just fine. anyone have any ideas? i dont know how many miles are on the motor so injectors could be a suspect but the IP is new. lift pump maybe also?
manostihl
Re: 1989 dodge w350 missing under load
Postby AHineman » Wed Jan 21, 2015 5:31 am
I'd start by changing the fuel filter.
Postby manostihl » Wed Jan 21, 2015 10:15 am
my truck only has a water separator on it thats how i bought it and i changed it not too long ago and i drained it twice yesterday. should it have another filter on it? the fuel is definately fresh as this truck is my daily driver and i regularly treat the fuel with the power service winter additive
manostihl
Postby CumminsPower59 » Wed Jan 21, 2015 10:22 am
manostihl wrote:my truck only has a water separator on it thats how i bought it and i changed it not too long ago and i drained it twice yesterday. should it have another filter on it? the fuel is definately fresh as this truck is my daily driver and i regularly treat the fuel with the power service winter additive
There is only one filter element on our trucks, it is a dual purpose unit...fuel filter AND water separator.
Postby manostihl » Wed Jan 21, 2015 7:59 pm
just changed it. seems to be about the same :mad:
manostihl
Postby CumminsPower59 » Wed Jan 21, 2015 8:25 pm
Probably got a sticky injector or dv....only thing I can think of...I doubt throwing filters at it wl do much. Does the miss increase its harshness as the RPM's increase?
Postby manostihl » Thu Jan 22, 2015 10:09 am
CumminsPower59 wrote:Probably got a sticky injector or dv....only thing I can think of...I doubt throwing filters at it wl do much. Does the miss increase its harshness as the RPM's increase?
dv??? it definately shakes less at higher rpms but the miss doesent go away or seem to get any worse
manostihl
Postby manostihl » Thu Jan 22, 2015 10:11 am
could valve lash have anything to do with it?
manostihl
Postby RCCUMMINS89 » Thu Jan 22, 2015 12:23 pm
Air, starving for fuel, fss, injector... can all cause a miss at high rpm.
Postby manostihl » Thu Jan 22, 2015 2:19 pm
RCCUMMINS89 wrote:Air, starving for fuel, fss, injector... can all cause a miss at high rpm.
Its not just at high rpm. Fss?
manostihl
Postby RCCUMMINS89 » Thu Jan 22, 2015 2:23 pm
Is it smoking white when it misses?
Postby matthewh » Thu Jan 22, 2015 3:32 pm
FSS is short for Fuel Shutdown Solenoid. If you look at the side of your injection pump, you'll see it, has 2 wires coming off of it. A bad connection, corroded wires, etc will cause it to randomly close, shutting off the fuel.
matthewh
Postby manostihl » Thu Jan 22, 2015 4:26 pm
RCCUMMINS89 wrote:Is it smoking white when it misses?
No it hazes like normal cold . And one it warms up it runs clean at an idle. It started missing like this when it was real cold and i didnt have her plugged in but it would warm up at a high idle and smooth out. I always let my truck run and warm up at the very least 10 mins. Also whenever i took it down the expressway at 65 as soon as i got off it would start smoking and missing. Then it would clear up after the truck sat and cooled off.
manostihl
Postby manostihl » Thu Jan 22, 2015 4:29 pm
matthewh wrote:FSS is short for Fuel Shutdown Solenoid. If you look at the side of your injection pump, you'll see it, has 2 wires coming off of it. A bad connection, corroded wires, etc will cause it to randomly close, shutting off the fuel.
O ok my solenoid is junk and shuts the truck off with the key when it feels like it i use the stop bar alot to shut it off although it just recently started workin ok hmmmmmmm. I know the wires and connections are good i tested them
manostihl
Postby manostihl » Thu Jan 22, 2015 11:16 pm
sorry yeah it actually is smoking white when i ran it after lashing the valves today
manostihl
