copper spray-a-gasket question
Postby jethro » Fri Jan 23, 2015 8:52 pm
Still working on bottom tapping the block for the a1 studs- that is coming along. may use some of the ultra-copper
aerosol spray from permatex. I have only used it once.
Do you normaly put it on both the deck and the head....... ?
and- does it hurt to let the film harden before installing the head on------ or do you want to try to do it quickly while it is still
unhardened. ????? I am wondering that since it is a thin film- does it matter ?
Any thoughts there ?
Tim
jethro
Re: copper spray-a-gasket question
Postby diesel freak01 » Fri Jan 23, 2015 10:00 pm
We used this last time on the tractor. We sprayed both sides of the gasket. Let it get tacky and install.
1993 d350 ctd drw 2wd auto
diesel freak01
Postby Ghostman » Mon Jan 26, 2015 8:23 am
When I put my rebuilt head on I o-ringed the block, and sprayed the copper gasket on block and head surfaces and lightly on gasket. then installed while was wet/tacky. Torqued OEM bolts to 135lb/ft and it's been holding good since.
Restoring a Early '91
2001 12v
(2) 2002 24v
Ghostman
Postby dazedandconfused » Mon Jan 26, 2015 11:59 am
I've never used it on a diesel but we use to always use it on 4cyl and 6cyl engines
Postby dpuckett » Thu Feb 05, 2015 11:44 pm
Pardon my ignorance, but what is the purpose of the spray-gasket stuff? I always insalled the HG dry, per the book. Never dug into any other engine that far.....
Postby CumminsPower59 » Mon Feb 09, 2015 4:53 am
I'm with Dan, never used it...not seeing the point with our trucks.
Postby DodgeFreak » Mon Feb 09, 2015 12:22 pm
Never used it on any engine other than. My suzuki 230 quad sport. I would reuse the mls head gasket countless number of times with copper coat on both side. Hang it by a bungee cord spray both sides wait till tacky and install.
Postby diesel freak01 » Mon Feb 09, 2015 7:51 pm
Might not see a use on these engines. The tractor was having head gasket issues and was trying to limp it along. Had too much crush on the fire rings, tried adding the copper coat to give more space for the fire rings and help hold the gasket in.
diesel freak01
