injector crush washers
Postby jethro » Tue Feb 10, 2015 8:45 pm
Have my injectors out (stock) - have to get them tested before they go back in.
I want to remove the copper crush washers off the end. They seem to be stuck on a little.
How do you get them to release without bending or distorting them. I will anneal them and reuse them
if I can keep from tearing them up.
Any practical thoughts ?????
jethro
Re: injector crush washers
Postby DodgeFreak » Tue Feb 10, 2015 8:49 pm
Why not buy new??? They wasn't that expensive.
Postby jethro » Tue Feb 10, 2015 11:28 pm
yes- looks like a whole set for everything is about 20 $
Maybe not worth saving !
jethro
Postby DodgeFreak » Wed Feb 11, 2015 5:24 am
I always grab them with pliers and twist them off....I don't think I damage them but I've never tried to save them. I know I've heard people that has reused them with good results but for 20 bucks I figure it wasn't worth the risk.
Postby Remps » Wed Feb 11, 2015 6:58 am
I always use a sharp knife and push it between the washer and injector to separate them. Once they move they are pretty easy to remove.
Postby ellis93 » Wed Feb 11, 2015 7:02 am
Fwiw I've reused some on 3 different sets,seems I can never remember to purchase some more. The only thing that ever gives me problems are the return line copper seals. They always seem to leak a little till they're tightened down in the same spot they were.
If you have the time to wait on them then get them.
Postby RCCUMMINS89 » Wed Feb 11, 2015 8:10 am
Runs $10-20 for a washer set. On my personal truck.... I've re used all of the washers about a dozen times. The super thin "215" washers should be replaced though.
Postby jethro » Wed Feb 11, 2015 11:36 pm
the ones on the end of the injectors look to be about .050 thick-
I will try a single edge razor blade in the crack.
Don't see any problem re-using them as long as you anneal them. (get red-hot-- quench in cold water while red hot--
that brings them back to dead soft and lets them conform to the texture of what ever they are up against and seal.
All ways do aircraft spark plug washers that way.
Only issue is that they might get gradually thinner over many anneal- cycles......
Tim
jethro
