Hey guys, My 93 W250 has a fuel pressure gauge, after filter. When I first got the truck, it would cary about 5lbs of pressure at idle. It started dropping down to almost nothing anytime I gave it any fuel at all.
I changed fuel filter, lift pump (twice), pulled the tank and pickup (tank and screen were clean) then I found all those stupid o-rings in the fuel lines. I replaced all those dang o-rings and finally, thought I had the problem fixed. Truck has been pushing about 6lbs of pressure at idle and 5lbs cruising down the road. Mash on the throttle and I can get it down to 0lbs.
Everything has been good for about a year. A couple of days ago, I let the truck warm up in the barn and it died while idling. I thought the fuel had gelled up, even though I had treated the fuel.
I put diesel 911 and fresh fuel in the filter and it fired up. only ran about a min and it died again. I put my spare filter in and now the truck runs. At idle, the turck carries 5lbs of pressure. If i bring the RPM up to 1500, it falls down to 0psi.
I have bled the system several times and even blew air back through the suction line, thinking maybe, just maybe there was an obstruction in the tank/screen.
I also treated the tank with whatever is in the white bottles (diesel 911 stuff, just white bottle) and also Howes treatment.
So now I'm ready to drop back and punt. I want to fix this thing, once and for all.
So I'm looking at this kit:
http://www.thehungrydiesel.com/Low-Pres ... t-Pump.htmThe problem is I still think I'm getting air in the lines or maybe there is an obstruction in the lines somewhere?? This makes me want to replace the fuel lines. As I'm sure you know, the fitting that hooks to the sump is just like the fitting on the lift pump, smooth metal that requires those stupid fittings with the o-rings. I want that all gone. So I found this:
http://www.thehungrydiesel.com/Diesel-F ... P-SUMP.htmIs this a good option? It says nothing about having a pickup installed. Anything more cost effective? I don't need billit anything. I just want it to work.
I could do a draw straw:
http://www.thehungrydiesel.com/Dodge-Ra ... II-DS2.htm Thing is I have read that you can't let your fuel level drop below a quarter tank. I don't like this. I use this truck. I haul with this truck. I fix fences, drive on steep slopes and do all the things you normaly do with a farm truck. Picking up air seems like a real issue with this design.
Is there anything I'm missing? Is there anything else I should be looking at that would cause my low fuel pressure?
Any other products I should be aware of that could solve this issue?
Mods to the turck:
Pump turned up a quarter turn before runaway
Smoke screw and star spun in quite a lot
ground fuel pin
4" straight exhaust
3200 spring
gauges
Thanks a lot for any input.
