to make post I will ask a question
Postby bennett_jacob » Tue Mar 03, 2015 8:43 pm
I could have done the research but might as well throw my question out I have a 90 with ve I wanna make good power with reliability I was told to just get a p pump motor and swap it in but won't p pumping my motor do the same thing and if I do will my injectors be a problem I heard they are bigger in size
1990 w250 4x4 he351 kit pump maxed getrag trans 4.10 gears 35 tires
bennett_jacob
Re: to make post I will ask a question
Postby ellis93 » Wed Mar 04, 2015 4:41 am
Mostly your problem with the injectors will be the thread size for the injector lines. The p pump injectors have 14mmX1.5 threads and the ve stuff uses 12mmX1.5.
As for the tips,the ve uses 6x9 while the ppump uses 5x9,5x10 for injectors. I believe they'd all flow similarly as far as throwing fuel. The injection pump difference in fuel flow would be the greatest difference between them.
Postby bennett_jacob » Wed Mar 04, 2015 9:34 pm
I'd love to p pump. With a kid coming in a few months that doesn't look like reality so for now decent price parts to get me moving a little faster would be nice. Like today I talked to a friend of mine all he does is scrap metal and he has a lot of turbos but they are all to small or I think they are I have the gds 60mm kit and it makes a lot but spools just a little too slow for the old getrag and I'm still having an issue making an intake for it. Thank you for that reply
bennett_jacob
Postby Remps » Thu Mar 05, 2015 8:40 am
Gov spring for 20 dollars would be a good bang for the buck.
Postby PToombs » Thu Mar 05, 2015 6:04 pm
Put a 12cm exhaust housing on your turbo, that will make it spool a lot faster. The other option is to get an HX35, (which has the 12 housing) and put your GDS 60mm kit on it.
Postby RCCUMMINS89 » Thu Mar 05, 2015 6:19 pm
12cm housing on your stock turbo, or an hx35, or an he351cw.
Fuel pin
Gov spring
Gauges
Exhaust
Enjoy it.... maybe do some pump tuning
Postby bennett_jacob » Thu Mar 05, 2015 6:44 pm
I already have gauges fuel pin 366 spring I have an intercooler from a 93 and pumping just working on getting the intake horn for it now I need a new afc for my pump it leaks and the pin that holds the fuel needle in is froze so it leaks a little I'm sure that will help. And will that 12cm run to hot the truck is my tow rig for the crawler. I didn't know the 60mm kit worked on the hx35 too
bennett_jacob
Postby bennett_jacob » Thu Mar 05, 2015 6:50 pm
Pump is turned up as well I'm waiting until the smoke clears up a but for bigger injectors
bennett_jacob
Postby RCCUMMINS89 » Thu Mar 05, 2015 8:03 pm
You'll be fine towing with a 12. If you are getting hot with it, you are over fueled for the turbo itself.
I wouldn't necessarily go much bigger (if any) over stock with injectors, with an hx35. If you do upgrade to the larger wheel..........5x12 at max is what I would recommend for towing.
Postby bennett_jacob » Thu Mar 05, 2015 10:29 pm
Thanks man I would really like to get close to 400hp but who knows tonight it's either I order the 4in exhaust or the exhaust housing but I'm also in the process of swapping an extended cab onto my chassis I'll do a build on it if I get a chance
bennett_jacob
Postby RCCUMMINS89 » Thu Mar 05, 2015 11:47 pm
Exhaust first. An exhaust housing can wait, meaning you can save up or wait for a better deal on an overall better turbo set up, like a 351cw, or a new turbo.
Hit me up, I'd love to help you out with your build.
Postby bennett_jacob » Fri Mar 06, 2015 8:34 am
I will hit you up most definitely I had a chance to get a 341 I thought it was a 351 at first but I decided it was too small and eventually I hope I get to the classifieds to look at the used section
bennett_jacob
