temp gauge swinging
temp gauge swinging
Postby shackwrrr » Mon Mar 09, 2015 9:03 pm
Driving down the road my temp gauge constantly rises to the 2/3rds mark then falls to half. Never stops and does it at any speed. Truck has new radiator and coolant is full. Gauge or sender? Possibly a thermostat?
1991 w250 RCLB
3 speed auto Non IC truck
shackwrrr
Re: temp gauge swinging
Postby matthewh » Mon Mar 09, 2015 10:27 pm
Does it do this more when its cold out? Could just be the thermostat opening and closing. If I don't have my grille cover on, or the radiator partially blocked when the cold hits, my temp gauge does the same thing.
matthewh
Postby shackwrrr » Tue Mar 10, 2015 5:56 am
I haven't driven it yet in temps higher than 50 yet. Just new truck anxiety. Trying to figure out all the "normal" quirks.
1991 w250 RCLB
shackwrrr
Postby Remps » Tue Mar 10, 2015 8:11 am
My guess is a cheap t stat was used. The parts store t stats tend to do that. I'd replace it with a genuine cummins t stat.
Postby RCCUMMINS89 » Tue Mar 10, 2015 11:02 am
Mine did that when my thermostat was installed upside down. There is a few holes on the thermostat, they need to be up when it is put in
Postby MARF75 » Tue Mar 10, 2015 12:08 pm
It's a cummins, they do that. The 3 first gens I've owned all did it.
I did some research on this and some of the second genners have drilled a tiny hole or 2 in the rim of the t stat to allow more water to flow thru when the t stat is closed.
What I got out of it is the cooling system works so well that when the stat opens it cools enough to shut the stat then it heats backup, stat opens and over and over and over and that's what you are seeing on your gauge.
MARF75
Postby shackwrrr » Tue Mar 10, 2015 6:42 pm
Thanks for the replies, I'll get an oem Thermostat at work (I work at a dodge dealership). I'll try it as is and if it still does it I'll try putting a hole in it. I did this on my turbo van with great success.
1991 w250 RCLB
shackwrrr
