Power woes....
Power woes....
Postby Hansen01 » Sat Mar 21, 2015 7:54 pm
Ok, sooo, as i was putting my truck back together i ordered a new set of nozzles for my injectors threw The Hungry Diesel. I had them put together and then i put them in. About a year after i put them in the truck was finally road worthy and all i could get out of it was about 30lbs of boost with my he351 cw, and the pump turned up. After turning the pump up to near runaway, screwing all the screws in, making sure that the AFC pin slides, making sure the wastegate is closed tight, changing some intercooler pipe routing, fuel filter, AFC hose, i am still at 34lbs of boost. I send them back to Eric and he flow tested them, and they checked out good at 73lpm or so, so i know they are good, but what gives?
Under construction...
Hansen01
Re: Power woes....
Postby Tacoclaw » Sat Mar 21, 2015 8:29 pm
Lift pump? Fuel supply lines? Suction screen in the tank?
Is it still smoking when is maxed on boost?
Re: Power woes....
Postby Hansen01 » Sat Mar 21, 2015 8:36 pm
It smokes very little at 30lbs mostly just a haze, fuel pressure gauge says between 10-12psi at all times
Hansen01
Re: Power woes....
Postby RCCUMMINS89 » Sat Mar 21, 2015 9:29 pm
I forgot, was this the same injection pump? Was anything else changed?
Stock intercooled injectors will make 30ish psi.
Re: Power woes....
Postby Hansen01 » Sat Mar 21, 2015 9:34 pm
Same pump, but it was rebuilt probably less than 10000 miles ago, nothing was done to it when the truck was down other than a small timing bump
Also for everyone else, it runs good, it's just it has what feels like the same power as before the nozzles, and roughly the same or less boost than before, still has a second gen intercooler in it, that was fixed and leak checked before install
Hansen01
Re: Power woes....
Postby Hansen01 » Sat Mar 21, 2015 9:56 pm
Also had probly 3 or4 tanks of new fuel run threw it with no improvement
Hansen01
Re: Power woes....
Postby PToombs » Sun Mar 22, 2015 5:31 pm
Bumping the timing will lower boost some, and EGT'S, but IMO it should run a little stronger. But if you haven't driven it in quite a while your "seat of the pants meter" could be off a little too. Maybe bump the timing more or less to see how much it changes?
Re: Power woes....
Postby Hansen01 » Sun Mar 22, 2015 6:36 pm
I could retard it some since I have yet to do that, but no more advance because it's too the head, RCCUMMINS said when he had the same setup he was making close to 60 and I stayed the same ( boost wise) :x lol if that's all its ever gonna get they need to be like 5x18s then lol
I did get new seats and new pants since last time tho Pete :lol:
Hansen01
Re: Power woes....
Postby oldestof11 » Sun Mar 22, 2015 6:53 pm
My HE351 with 370s only does 36psi. I KNOW the wastegate isn't wired as tight as it should be. When you say yours is closed tight, HOW is it keeping closed?
Re: Power woes....
Postby Hansen01 » Sun Mar 22, 2015 7:37 pm
Piece of wire from the Wastegate to a bolt on the manifold
Hansen01
Re: Power woes....
Postby oldestof11 » Mon Mar 23, 2015 2:21 pm
That is how mine is. Any bit of play is bad.
Re: Power woes....
Postby Hansen01 » Mon Mar 23, 2015 8:20 pm
Haha yea I know, when I first wired it up a couple years ago I didn't wire it to the engine, and everytime the engine twisted it got loose, I felt really dumb lol
Hansen01
Re: Power woes....
Postby RCCUMMINS89 » Tue Mar 24, 2015 4:53 pm
It is a fueling issue. It should literally black out the highway at 30psi, even 40 or 50 psi. Those injectors are fairly big.
What are you seeing for egts?
Re: Power woes....
Postby Hansen01 » Tue Mar 24, 2015 6:30 pm
1300-1350 MAX,and you really gotta hold it there to get that hot.
I can't hardly believe it would be in the pump,but can anyone think of anything I could check in that area before I gotta take it off and get it looked at?
Hansen01
Re: Power woes....
Postby RCCUMMINS89 » Tue Mar 24, 2015 6:33 pm
Is this have an i/c? Those are really hot egt for 30psi, you shouldn't be seeing those until you are up past 40 with a 351cw
