M14 injector fitting??
Postby LandTug2 » Mon Mar 23, 2015 1:38 pm
Well ordered some 6x16 injectors from Rocken Tech. Heard mixed reviews but thought I would give them a go. Told them I needed injectors for a 93 intercooled CTD. They said no problem, shot a set out. First off they sent 9mm injectors instead of 7mm injectors. Sent them an email and they shot out another set speedily. Just got them all in happy I had the right ones and went to put the lines on just to find that the male end of the injector is too big for the stock fuel line fitting! Looked at their website and saw that it says M14x 1.5 orifice size and I believe ours are M12x 1.75... . Why would they do this in the first place??? Do they expect us to have aftermarket lines? Has anyone else run into something like this? If so, what was the remedy?
'93 D250 5x16s, Stg1 pin, 3200 gov spg, stiffer afc spring, pump tuning, Super Harmonic Damper, Timing Spacer, hx35/ht3b compounds, 100 gpm lift pump, 12" Cone filter, Moog Springs, pyro/drive pressure/boost/f. pressure/tach gauges,valet switch, 4'' straight pipe, mag hitec dif cover
LandTug2
Re: M14 injector fitting??
Postby BC847 » Mon Mar 23, 2015 2:26 pm
Sounds like they used '94 and up P-pump injector bodies. (I'm guessing).
Postby LandTug2 » Mon Mar 23, 2015 2:39 pm
Thank you for the response. Well dang that is disappointing if that is the case. I contacted Rocken Tech in the mean time to see if they have a solution. Do you have any suggestions to get her back on the road in the mean time? I thought of maybe cutting down the threads on the injector but not sure how well that would work.
LandTug2
Postby BC847 » Mon Mar 23, 2015 2:56 pm
I'd get my money back and go with a reputable vendor. Perhaps you might consider The Hungry Diesel http://thehungrydiesel.com/
Postby LandTug2 » Mon Mar 23, 2015 3:01 pm
Yea that might be the best bet. Disappointing.
LandTug2
Postby RCCUMMINS89 » Mon Mar 23, 2015 8:42 pm
LandTug2, pm me on CF ( I saw your post there too ), or call me. We have some options here....... If they do give you a hard time, we commonly cut down p pump bodies for ve threads. We also carry a wide variety of 5 hole, and 6 hole injectors. With very high quality edm and hone work.
Postby LandTug2 » Thu Apr 30, 2015 10:18 pm
Sorry for the reeeeaaally late response rc, thank you for the options. Definitely got burned on that deal. Stuck me with a 30% restocking fee because they were "heavily used" Anyways, I would have gone to you for some new sticks but had a new set of 5x16s fall in my lap for free so those went in. Ill let you know if these dont work out though!
LandTug2
