can't get truck to start
Postby countrymoparguy » Sat Mar 28, 2015 7:30 am
So after fixing a leak from an o-ring on the back of the injection pump, truck won't start now. I pulled the pump, replaced o-ring and threw it back in. Primed the system, got fuel to the injectors. Cranks good, getting fuel but won't fire. Any suggestions as to what to check next? Thanks for the help. It's a 93 also.
countrymoparguy
Re: can't get truck to start
Postby fatty » Sat Mar 28, 2015 9:21 am
Which oring did you fix? How much apart was the pump when you had it off?
Postby RCCUMMINS89 » Sat Mar 28, 2015 9:38 am
Keyway not in the timing gear correctly is the first thing to check.
