cleaning up under the hood
Postby cummins king » Thu Dec 13, 2007 9:06 pm
okay my cruzie dosnt work and i dont care, below the brake stuff there that weird cone looking thing that got a hose or two on it (on drivers side fender) what exacly is it and do i need it im going to remove all the extra crize lines too.
93 4X4 auto
cummins king
Re: cleaning up under the hood
Postby flashgordon » Thu Dec 13, 2007 10:01 pm
cummins king wrote:okay my cruzie dosnt work and i dont care, below the brake stuff there that weird cone looking thing that got a hose or two on it (on drivers side fender) what exacly is it and do i need it im going to remove all the extra crize lines too.
If it's the same thing as i thing it is..............it a sw. to turn you brake light on, in you dash, when your vac. get below a safe level.
Flash.
flashgordon
Postby PToombs » Fri Dec 14, 2007 6:17 pm
Yup, what Flash said, switch for low vacuum light.
C K, you doing away with cruise? Wanna get rid of the brake light switch? Or swap for a regular one?
Let me know!
Postby GO OVRIT » Fri Dec 14, 2007 7:37 pm
I'll take the clock spring out of your way :D ....you know, to help clean up inside the steering column.
GO OVRIT
