Turbo info
Turbo info
Postby ellis93 » Thu Apr 16, 2015 8:21 pm
Ran across this nugget while trying to decide on the hy35 on the 24v
http://dodgeram.org/tech/dsl/FAQ/turbo_faq.htm
May be a useful link to stick in the sticky section
Re: Turbo info
Postby Remps » Fri Apr 17, 2015 10:14 pm
Keep in mind when they say the compressor is good for 44 psi, that psia, not psig. You have to add atmospheric pressure to gauge pressure, and divide that by inlet pressure to get the pressure ratio. So 29.3+14.7=44 psi. 44/14.7=2.993, about a 3 to 1 pressure ratio, where the hx/hy compressors push max volume. Also have to add pressure drop across air filter and/or intercooler into those equations.
