CAT Fuel Filter
Re: CAT Fuel Filter
Postby 762frmafr » Thu May 07, 2015 5:57 pm
THD piston lift pump was installed today. It is running 13.5 psi of fuel pressure and does not got down but maybe 1-2 psi at WOT. I ordered the 15 psi pump and with the goldenrod filter installed I think 13.5 psi is respectable. I will update along the way as to the durability and longevity of the filter set up as well as the pump itself.
762frmafr
Re: CAT Fuel Filter
Postby RCCUMMINS89 » Thu May 07, 2015 6:05 pm
Good info, thank you.
Re: CAT Fuel Filter
Postby 762frmafr » Thu May 07, 2015 6:09 pm
RCCUMMINS89 wrote:Good info, thank you.
Eric, keep an eye on your mailbox next week as well.
762frmafr
Re: CAT Fuel Filter
Postby RCCUMMINS89 » Thu May 07, 2015 6:42 pm
OK....
Re: CAT Fuel Filter
Postby 762frmafr » Mon May 11, 2015 6:12 am
Drove 200 miles round trip yesterday and the fuel filter and new pump seem to be holding up and doing their job excellently.
762frmafr
Re: CAT Fuel Filter
Postby RCCUMMINS89 » Mon May 11, 2015 11:48 am
I'm going to put some pictures of later of what you sent me..... you're the man, thank you.
Re: CAT Fuel Filter
Postby 762frmafr » Tue May 12, 2015 6:35 am
After 400 miles with the GoldenRod filter, there is already sediment in the bottom of the bowl. Seems to be doing it's job. Fuel pressure is still between 13 and 15 psi at all times.
762frmafr
Re: CAT Fuel Filter
Postby 762frmafr » Mon Jun 01, 2015 12:17 pm
After 1000 miles with the Goldenrod filter, it is still holding up and my fuel pressure is still between 13 and 15 psi.
762frmafr
Re: CAT Fuel Filter
Postby 762frmafr » Thu Jul 09, 2015 12:06 pm
I just came back from a 3700 mile road trip with my First Gen. Fuel pressure dropped on the return leg of the trip from 12-15 psi to 6-9 psi. I just changed the filter element in the Goldenrod filter and fuel pressure is back up to 15psi. I couldn't be more happy with this set-up.
762frmafr
