Throttle linkage help
Postby 93cummins89 » Thu May 07, 2015 9:51 am
91.5 auto with cruise 5.9diesel w/IC - I have 3 throttle links on got to pedal one goes to trans and other goes to vacuum. I'm deleting curise and need to know if I need to keep the one that goes to trans or not
93cummins89
Re: Throttle linkage help
Postby matthewh » Thu May 07, 2015 3:21 pm
Yes you do, that linkage is your "kickdown" cable persay. Since your right there, may not ba a bad idea to check and make sure its adjusted properly
matthewh
Postby 93cummins89 » Fri May 08, 2015 1:04 pm
thanks. got any info on how to do that?
93cummins89
Postby matthewh » Fri May 08, 2015 3:19 pm
If I was more technology capable, id paste a link to it over in the sticky section of diesel truck resource. But if you go to dieseltruckresource.com, in the 1stgen section there is a sticky, has almost everything one needs to know about these truck.
Its been so long since I had an auto I cant remember the setting
matthewh
Postby 93cummins89 » Sat May 09, 2015 8:17 am
thanks. kinda regretting the whole automatic thing now. and iv learnt that the next diesel i buy will be 2000 or newer
93cummins89
Postby cougar » Sat May 09, 2015 8:45 am
Might I suggest 03 or newer. My 01.5 has been such an expensive PITA I will not do buy another 2nd gen 24 valve.
01 2500 "the work truck".
cougar
Postby 93cummins89 » Sat May 09, 2015 9:04 am
dont get me wrong i love the square bodys and old school mechanical cummins. but dang i never would have thought wiring and parts would be such a PITA
93cummins89
Postby Remps » Sat May 09, 2015 3:19 pm
On the tv cable.. set it where it shifts best. I find the linkages are so sloppy that getting it set to factory setting is a crapshoot at best. Once you change pump fuelling from stock it (the tv cable) needs to be readjusted to get the trans to shift optimally. Newer trucks...suck. This is 1stgen! :mrgreen:
Postby 93cummins89 » Sun May 10, 2015 7:27 am
Kool thanks. 1st gen forever
93cummins89
