what engines can be swapped into a g1 teg
Postby Prince91 » Sun May 10, 2015 2:03 pm
I know you can do a bseries but what other engines can be swapped in without a problem or what measurements would one check if wanting to swap any other engine in thank you
If google cant help you find your old school parts, try nwch!
Prince91
Re: what engines can be swapped into a g1 teg
Postby simplysmn » Mon May 11, 2015 10:13 pm
I wouldn't worry about anyother swap I would just use a B Motor
simplysmn
Postby Prince91 » Tue May 19, 2015 3:15 pm
simplysmn wrote:I wouldn't worry about anyother swap I would just use a B Motor
Yea but i saw someone do a plateless set up for a h2b set up and want to try something out since you wouldnt need to use different mounts but the b series ones
Prince91
Postby RumbleFish » Tue May 19, 2015 4:02 pm
Teg, as in integra? This site is for 1st generation Dodge diesels so I dont think we are going to have much help to offer.
