Begle1 wrote:The 5-sided "special washer" on the side of the injection pump. What does it do?
PToombs wrote:It's only a spacer. When you want to lock the pump from turning, like when you pull it, you pull that out and tighten the bolt. When you put the pump back in, you loosen the bolt, and insert the spacer, then snug the bolt.
If the bolt isn't tight when you pull the pump, it will turn off #1. Which is ok if it's going to get rebuilt 'cause they will lock it. If you are just removing and installing for another reason, this will suck!![]()
PToombs wrote:The pin is only plastic. The tip usually breaks off. It's held in with a star washer jammed in the outer piece. If the washer has been disturbed, it falls out easy, then the pin.
