Draining coolant from block
Postby ArtBee » Sun May 31, 2015 10:35 pm
Hello.
I have looked and can't find an obvious plug to remove from the side of the block in order to drain all the coolant out. Am I blind or is there not one (or two)?
Thanks
Art
1993 W350, 1991 D250 (non IC), 1969 Plymouth GTX, 1961 Chrysler 300G, 1966 Chev BelAir
ArtBee
Re: Draining coolant from block
Postby Turbo67 » Thu Aug 13, 2015 10:52 pm
I have wondered the same thing. I have been under the truck a few times since I bought it, but nothing stood out to me as drains.
Anyone have any input to this?
Turbo67
93 Cummins 5.9L, VE Pump, 300,000 miles
4200 RPM Spring, indexed stock fuel pin, Fuel Screw maxed, then replaced with longer "Hot Screw", aneroid screw tweaked
Turbo67
Postby PToombs » Fri Aug 14, 2015 5:32 pm
Yes there is one, I just can't remember exactly where it is. :oops:
Postby cmauz61 » Thu Aug 27, 2015 7:40 am
pull the rad hose drain it. fill it with water. run the truck drain it and repeat until your happy lol thats what I've always done.. not sure if its correct though. but it should clean it out
1992 dodge w250 12v
4" turbo back exhaust, denny t fuel pin, 12mm pump cranked, 4,200 rpm spring, afe intake/filter, egt gauge, boost gauge.
cmauz61
Users browsing this forum: No registered users and 57 guests
