opinions on U-joints
Postby jethro » Tue Jun 02, 2015 10:43 am
I had to shorten my front drive shaft. I am replacing all the universals as I go.
I got the front one first. (so far)
I got the Chinese one for like 8$
They had an American one for 28$
Both have grease fittings where the ford (spicer-180K miles) did not.
I don't expect to be pulling big loads-
Do yall think the extra 20$ per joint is worth it ?
Anyone have bad experiences with the cheaper ones ??????
I have 2 more to put in yet- I can save the Chinese one for a spare if need be !
(then I get to spend 100$ to get it re-balanced when I am done)
Opinions appreciated !
Tim
jethro
Re: opinions on U-joints
Postby jethro » Tue Jun 02, 2015 10:15 pm
all ready decided to abandon the Chinese junk- I have come too far doing everything right to put in a part that
may blow up at the worst possible time.
I looked at the rollers under the microscope- they didn't look that great- kind of on the rough side I thought.....
I wouldn't dream of putting Chinese bearings in any other part of a vehicle- why would I want to compromise my reliability now ??????
Tim
jethro
Postby RumbleFish » Wed Jun 03, 2015 8:14 am
I sell lots of ujoints. You definitely get what you pay for.
Postby ellis93 » Wed Jun 03, 2015 10:35 am
What he said ^^^^
But.....even the best are sometimes a bitch to get put in. Sometimes I even have to trim the trunion or cap surface to get a u joint to move free or get it to quit speaking. It sucks to have to pull a joint down two and three times to get a proper fit.
Postby jethro » Wed Jun 03, 2015 7:57 pm
the first one I push out- it took most of the 30 tons that my press had to give. I would say that is too tight.
After I got it apart I lightly ran a brake cylinder hone in the bores to disclose high spots- which I relieved.
That seemed to help quite a bit.
jethro
Postby 93cummins89 » Sat Jun 06, 2015 6:41 pm
Moog is the only way to go.
93cummins89
Postby matthewh » Sat Jun 06, 2015 8:12 pm
I usually run greaseable Spicer units. Find the quality far superior to house brand units
matthewh
Postby ofelas » Tue Jun 23, 2015 5:48 pm
I like the Spicer Life non greasable units.
R12 = liquid bilit
ofelas
Postby u2slow » Mon Jun 29, 2015 9:01 am
I recently bought GMB ujoints from rockauto. Made in Japan. Cheaper than anything else. Going to give them a shot.
93 W250 Club 6BTA/5spd/3.54/Dana80/~3"lift/2gen leafs/3gen wheels/HX35/5x.012s
90 D250 6BT/5spd/3.54PwrLok
84 Ramcharger [Project} D250 6BT/5spd/3.07
... various other 75-05 mopar truck products
u2slow
Postby Remps » Mon Jun 29, 2015 12:04 pm
I recently installed quality gear greasable u joints on my w250 rear ds.They claim to be 30% stronger than spicer u joints, and were $17 for the front u joint, and $27 for the rear conversion joint. Hopefully get to try them out in a couple weeks.
